Which size trowel is appropriate for 12x24 porcelain tile?
Old 11-08-20, 06:27 AM
I'm doing my shower all and the floor in the same tile which is 12x24. The wall and floor are both hardibacker. I did some reading and is almost seems like I could go with a couple trowels. Home depot sells a 1/4 x 3/8 x 1/4 and a 1/2 x 1/2 x 1/2. I figured I'd check in here. Your thoughts?
Old 11-08-20, 06:40 AM
XSleeper's Avatar
Received 897 Votes on 823 Posts
That is considered a large format tile, so you would use 1/2x1/2 and back butter the tiles.
Old 11-08-20, 06:48 AM
P
Received 855 Votes on 789 Posts
Definitely back butter the tiles. I put a dollop of thinset on the back of the tile and use the smooth side of the trowel pushing hard to force the thinset into intimate contact with the tile. Make sure the entire back got a thin smear of thinset and don't be afraid to remove any excess.
