saltillo tile - cutting?
I am laying square Saltillo Tile (aka Mexican pavers) over a concrete base, about 400 square feet.
1. What is the best way to cut saltillo tile? Can I use a manual saw vs. electric wet saw?
2. I plan on using basic mortar mix Type M, for the bonding agent between concrete and tile. Am I safe?
Thanks for the help. It is really hard to get information on working with Saltillo type tile.
E
E
Equis, (Dos Equis? Tres Equis?)
Although it's possible to cut Saltillo tiles with certain hand saws, it's not feasible on a 400 square foot job. Get a wet saw.
Type "M" mortar is a portland/lime mix intended to be mixed with sand. It's used for laying brick and block. It is not the material of choice for fixing Saltillo tiles to a concrete slab. Use thin set mortar instead. You can expect to get 35-40 square feet per 50 lb. sack. Make sure your pavers are damp when you install them.
John
http://www.johnbridge.com
John
