Sub Floor water damage
Old 12-30-21, 02:54 PM
Received 1 Upvote on 1 Post
Hi. I'm renovating my guest bathroom. Ripped up the tile and cement board. Looks like some water damage between the tub and toilet area. I plan on using ditra over the sub floor. There's some slight give in the damaged area. Does this area have to be replaced? I'm a novice with sub floor issues, so how do I go about replacing if necessary? The house is 15 years old if that means anything. Thank you and HNY!!!
Old 12-30-21, 06:03 PM
Received 3,485 Upvotes on 3,128 Posts
That's a problem. Any give will cause the tile to pop.
Is it the sub floor or what is holding the sub floor up ?
Old 12-30-21, 08:57 PM
Received 1,197 Upvotes on 1,152 Posts
Yes, this needs to be addressed. Remove the subfloor and then ensure the structure underneath is in good shape or fix it before replacing the subfloor.
Old 12-31-21, 05:45 AM
P
Received 1,849 Upvotes on 1,655 Posts
Water damage around the toilet is very common and does need to be addressed. Not only will a soft underlayment cause the tile to pop but in that area it can cause the toilet to leak... causing even more damage. You want the floor rock solid around the toilet.
Old 12-31-21, 12:12 PM
Thanks. I'll cut out the bad parts and install new.
Old 01-04-22, 02:28 PM
Before I cut out the subfloor, I know I'm going to have to block the joists to create a "ledge" for the new subfloor patch to sit on. However I know I have engineered I joists. The pic attached is a view from my basement to my first floor. I know the joists are the same as where I need to fix the sub floor. How do I add perpendicular support between the I joists...how do I go about adding parallel (sister?) support to these I beams? Everything I found online shows non-I beam style joists. Thanks.
Old 01-04-22, 02:35 PM
I just glue and screw 2x lumber between the flanges.
Old 01-04-22, 02:40 PM
The flange is only about 1" wide. And the area between the top and bottom flanges is about 9" with the span between joists about 12.5". So you're saying cut a 2x9x12.5 and wedge it perpendicular. Then screw through the top flange into the 2X?
