Used wrong tape on Durarock
Old 03-18-22, 10:50 AM
L
I am finishing the surround around a tube and installed durarock board. When I went to tape the corners and seams (with Schluter All Set), I grabbed my sheet rock mesh tape instead of my alkali resistant tape. Didn’t notice I had used the wrong mesh tape until I was finished. My question is…. Should I put another layer of tape and thin set over what I have done, remove the tape and replace (seems like this would be a real pain) or just go ahead and use what I’ve done. This bath is in a basement on a slab, the walls should never seen any movement or live load.
Old 03-18-22, 11:00 AM
XSleeper's Avatar
Received 1,749 Upvotes on 1,573 Posts
I think I'd just press on. It will probably be fine. Adding another layer would likely just create a bigger hump on a wall that you'd rather have as flat as possible.
marksr voted this post useful.
Old 03-18-22, 11:02 AM
L
My thoughts also. Sorry for the duplicate posts. Any idea how long fiberglass lasts in concrete before it starts to degrade?
Old 03-18-22, 11:08 AM
XSleeper's Avatar
Nope. But I would imagine it would last longer if you applied a waterproofing (Redgard) over it to keep the cement board dry.
Old 03-18-22, 11:12 AM
L
That’s when I discovered I used the wrong tape, LOL. I went to grab my Redguard and my roll of alkali resistance tape was laying next to it, unopened.
Old 03-18-22, 11:13 AM
XSleeper's Avatar
Lol!
