We had our bathroom completely redone back in 2018. It's normal to have caulk running over the grout / tiles along the edge where floor meets walls?
In those 5 years, I've taken off the caulk a couple times now to recaulk due to black discoloration under the caulk (that's mold, right?).
I use the GE bathroom silicone with the supposed anti-mold features. It seems to me that the mold is on the wall / grout not on the caulk? A technicality? They say the mold won't grow on the caulk. But it doesnt kill the mold if it's on the wall / grout next to the caulk?
Even though I clean the surfaces, let it dry for days before and after caulking, etc.... water will seep in the grout on the floor to the edge behind the caulk and grow there happliy?
We have a bathroom fan on a timer that runs for 30 minutes when showering.
Am I doing something wrong? I've tried grout sealants. as much as I think 1 said it's good for 10 years, waler beads initially, but within weeks / months, the grout turns dark when taking a shower (the water is getting into the grout?
Any tips if I am doing something wrong here? Or mold / recaulking is a task to do every couple years? The tiles are about 2" x 2".
Was the shower constructed with a waterproof enclosure or just tile on backer board?
My shower was built in 1986 without a waterproof enclosure. A 2016 renovation revealed disintegration of the wall structure opposite the shower head.
Exterior wall structure in shower disintegrated.
For years before that mold would grow in the silicone caulk joint at the bottom of the tile wall and floor. The copper floor pan prevented leakage below but the wall damage apparently was from water seeping through the tile wall toward the outside.
If you have a waterproof enclosure (Kerdi, etc.) you might just not caulk along the floor joint and leave it open for water to seep out and evaporate.
Most current building science recommends a water barrier right behind the tile... so that building materials stay dry and anything moist can dry to the exterior side... anything on the interior side of that barrier dries to the inside.
An example would be Kerdi or Redgard over backer board.
This is our kitchen floor put in by the previous owner more than 30 years ago. We actually have left over tiles they left in the basement.
Over all these years, it's gotten little chips & nicks in the top surface. mostly look like white specks and are not that big.
We are not interested in throwing lots of money / time / effort into this. I am certainly not going to cut out whole tiles to replace them and regrout around them - the grout won't match and if I do it, the new tiles will likely not be as level as the rest of the floor, etc.
But if there's touchup pens or some other ideas you have, I'd love to hear them.
Any tips / recommendations / products we can use to make these small damage spots less noticeable. Not so much that they are level with the rest of the surface - they really aren't all that deep.
Different shades of brown / tan sharpies? any other thoughts?
THANKS!
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/2023_09_07_09_27_18_cfb84f14b1d8c21050bddc6ef8d417172d0c54bb.jpg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/2023_09_07_09_27_27_0110256354bfebac019b2404b8784d07c7d8651d.jpg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/2023_09_07_09_27_33_e852ef8bea4d6c16e31f9e139ec592f3ffbeca67.jpg[/img]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/2023_09_07_09_27_44_5e5e8c70e5e91500ce1c59b8d55c403b47aa7525.jpg[/img]
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/2023_09_07_09_28_01_cfb408d80d5a81a71a1f55ecd2b3b5a83931f20d.jpg[/img]
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/2023_09_07_09_28_14_423d93fea96d225f73462e76e303f2f1db4dc7c8.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/2023_09_07_09_29_09_ee9981870c1e99a071c23afd08a26dcdd5a706fe.jpg[/img]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/2023_09_07_09_29_30_40eb5ebca52f49f9e2b1b62f81413610c7adcb83.jpg[/img]
Read More
I'm in the process of fixing up a house I inherited and the master bathroom shower needs a good bit of attention. I'm not sure what to do with the shower walls. They look like some kind of stone but they are dull and have some light scratches on them. They seem to attract water marks and soap scum very easilly.
Can anyone identify what type of stone or material they're made of? Also, what would be the best way to clean them to remove the haze and get a glossy type finish? They don't look bad wet but when they dry they have a dull dry powdery look. Is there some type of clear coat or sealer that would help?
[img]https://cimg1.ibsrv.net/gimg/www.doityourselft.com-vbulletin/726x1292/pxl_20230806_143807005_night_1a2bcd21c1a80af72de105930994c55e15a1b877.jpg[/img]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/726x1292/pxl_20230806_143828608_night_a55a9dcadfa2d5d4cc6d387f715d233a4c390b42.jpg[/img]
Read More
