Bathroom floor
Old 06-09-24, 10:36 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Bathroom floor
Hi All, need suggestions for installing ceramic floor tile in a bathroom, I would assume that Thin Set mortar would be the best, any thoughts?
Thanks
Geo🇺🇸
Old 06-09-24, 06:57 PM
Received 1,280 Upvotes on 1,218 Posts
Yes. Other questions?
As far as the basics, what is the composition of the subfloor along with the size, spacing and unsupported span of the floor joists?
sam floor voted this post useful.
Old 06-10-24, 04:31 AM
Geochurchi's Avatar
Subfloor is OSB 1” or 1 1/4” , good condition, any thoughts on using Redguard over subfloor? Area is about 25 Sq ‘
Geo🇺🇸
Old 06-10-24, 06:13 AM
Received 869 Upvotes on 760 Posts
Redguard shouldn't be needed in a dry area although it won't hurt to use it.
Old 06-10-24, 11:43 AM
Did you mean a Kerdi membrane? That would be ok. As Mark said, I don't see the need for Redguard,
Old 06-13-24, 11:43 AM
H
Received 9 Upvotes on 9 Posts
OSB is not a good substrate for setting ceramic tile. You need to use either a sheet membrane (like ditra) or a liquid membrane (like redgard - applied at the proper thickness). The sheet membrane is a better choice.
Old 06-13-24, 11:48 AM
Geochurchi's Avatar
Thanks, my choice will be Redgard as I don’t want want to raise the height anymore than necessary.
Geo🇺🇸
