Replacing single tile
Old 07-19-01, 02:46 PM
I installed 12" X12 " tile this weekend and one had a hollow sound when I stepped on it. Since I have not applied the grout I tried to lift the tile and it came right up. I used 3/8 x 1/4 trowel on 1/4" wunderboard. How do I reapply the tile?
Old 07-19-01, 05:15 PM
Hi Melvin,
We would use a new tile. If you want to try to remove all the thin set from the back of the one you have, you may be able to sand it off with a belt sander or a disc sander.
John
Old 09-01-01, 08:32 AM
lumenaider
Thumbs down
My FEDDERS CKE036A fins on the coil are smashed in places not letting air through. I tried to clean and straighten, but they seem to be falling apart. Can just the coil unit be replaced or do you have to replace the whole air handler? How much should it cost to fix?
