Using a Coping Saw To Cut Tile?
Old 07-19-01, 09:15 PM
Guest
Smile
I read on the diy.com website you can use a coping saw to make odd cuts. I was wondering if this is true and what type of blade would work? I'm having problems cutting around the door frames and I don't want to cutt into the frames themselves to make space for a tile. Any help would be greatly appreciated! Thank You!
Old 07-19-01, 09:43 PM
A
You can buy a carbide rod saw in most tile shops or departments. It works ok on wall tile...but is a complete waste of time and money on floor tile...it's just too hard.
Old 07-19-01, 10:04 PM
Guest
Smile what would you suggest?
Thanks for responding!
Old 07-20-01, 02:44 PM
A
The easiest and least expensive soulution is to rent a diamond blade water saw from a tile shop or rental store..probably $35 a day?
Old 07-21-01, 02:44 PM
And undercut the door trims. It's the professional way of doing things.
John
