Securing a pedestal column to tile floor in bathroom
Old 07-26-01, 02:01 PM
budeyone
My wife and i just purchased a pedestal sink, and i will probably have to secure the column to the tile floor. Is there a special tool/bit i should use so as not to crack the tile?. Maybe i can just use a sharp drill bit?.
Also, i will need to cut tile to place around the baseboard in the bathroom. I would think the rental center has a small tool to do this project, rather then renting wet tile cutter.?
Thanx.
Old 07-26-01, 04:26 PM
You just set the pedestal on the tile and use a little latex caulking to hold it in place.
Yes, you can usually cut tile for baseboards with a tile cutter.
John
http://www.johnbridge.com
