I have a unglazed ceramic floor in my kitchen. Some of the grouting is coming up, so I would like a name of some type of product I can use to seal my floor. I would like some type of a shine. Thanks ClaudiaRead More
I'm planning on using wonderboard mounted on ceramic risers behind a woodstove. My problem is this. I'm using half inch board attached to wall studs every sixteen inches or so. Even with this many the board still has movement when pushed. It bows under pressure. I plan on putting ceramic tiles over the wonderboard but am concerned that the flex in the board will screw things up.
I'm pretty sure that this is fairly standard stuff for behind a stove but I can't figure out how the smart guys install it to make it rigid.
Thanks
Derek Roberts
Read More
