tile behind woodstove
Old 08-08-01, 02:28 PM
Guest
I'm planning on using wonderboard mounted on ceramic risers behind a woodstove. My problem is this. I'm using half inch board attached to wall studs every sixteen inches or so. Even with this many the board still has movement when pushed. It bows under pressure. I plan on putting ceramic tiles over the wonderboard but am concerned that the flex in the board will screw things up.
I'm pretty sure that this is fairly standard stuff for behind a stove but I can't figure out how the smart guys install it to make it rigid.
Thanks
Derek Roberts
Old 08-08-01, 04:03 PM
Hi Derek,
Tape the joints well. When you install your tiles and grout them, the installation will firm up considerably. Use thin set as your adhesive, not mastic (glue).
John
http://www.johnbridge.com
Old 08-08-01, 07:19 PM
Guest
Thanks,
Wish me luck!
Derek
