Grout line
I am installing 12-inch ceramic tiles in my bathrooms and kitchen, how wide should the grout line be? Are there advantage of one width over the other? Personally, I like the grout line as narrow as possible, what is the smallest size?
Thanks.
Thanks.
Hi
It's best to stick to about 1/4 inch for your grout line..you'll find that the tile is not all the same size, and if the joint size is too small, you may run out of joints completly...leave yourself a little room just in case.
