grout haze on tile
Old 12-11-01, 01:34 PM
Guest
Question grout haze on tile
My husband and I just installed tile on our floor and after wiping off the extra grout we got the haze, however now we cannot get it to come off. We have tired repeated wiping with a damp cloth and immediately buffing with a dry cloth and we have no progress. How do we get this off?
Old 12-11-01, 03:13 PM
T
Received 1 Upvote on 1 Post
Removing grout haze
There are commercial cleaners available for grout haze. Most folks report the greatest success using an old terry cloth towel and briskly rubbing off the haze.
Old 08-23-02, 06:58 AM
coach8
grout haze
What worked for me is a bucket of water only and a mop. The tile came up clean as a whistle.
Old 08-23-02, 04:04 PM
You let it dry out too much before you started the wiping process.
Mix your grout and let it sit for 10 minutes. Then remix good. Spead the grout. let it sit for 15-20 minutes. Then wipe down forming your grout lines.(don't use too much water) Then wipe again in one direction, not back and forth, which smears grout haze. then come back and wipe down again. what is then left will buff off with a dry towel.
Now that the grout haze has thoroughly dried, you may have to use a green scotch brite pad.
Old 08-24-02, 04:57 PM
kenji
Exclamation haze
If you left the grout dry with the haze on you'll never get it off,but you can find many products that can help you if the tile is glazed good luck!!!!
