ceramic tile sub floor
What is the proper base over wood subfloor for a new upstairs 85 sf bathroom ceramic tiling project?
Do I need 'green board', or is a base of 5/16 plywood underlay (primed to assure adhesion) over the double layer of plywood sufficient? If I need to install green board do I rip up the top layer of the plywood subfloor to maintain finished floor elevation?
On three previous ceramic tiling projects I've used the 5/16, and it has held up great for over 5 years (so far)... but none of these previous jobs have covered as large an area.
Thanks for any advice you can give... don't want the joints to crack
Hi
Here are the minumum requirements for ceramic tile. 2x10 joists 16 inches on center, with 5/8 ply on top of that. On top of that you should use 1/2 inch concrete board and then the tile. Since you already have 2 layers of plywood, it's probably ok to use 1/4 backer board on top. Green board is for walls only..and in a wet location, it's unsuitable for walls too.
