How for should I space marble tile apart?
We are about to lay marble tile in our bathroom. The marble is 12x12 tiles. How far should I lay them apart?
Also a couple other things to be carefull with marble is up here in Canada we have been getting some black and green marble that is much softer than most and should be set with epoxy mortar instead of thinset mortar. There have been many problems with the marble warping when installed with thinset mortar.
The other thing is if it's a light colored marble it should be installed with white mortar because sometimes grey mortar can be seen through the body of white or light colored marble.
I hope this helps.
P.S. I agree with 1/8 inch spacing or less and grouting with NON-Sanded grout.
I hope this helps.
