ceramic tile on countertops
I have the regular cheap laminate countertops i want to put tile can i tile directly over the current countertop and can i use the same mortar as used on floors?
Your best bet is to apply the 1/4" wonderboard right on top of the counter. First trowel on thinset, then lay the board down in the thinset, Screw the board down every six inches or use 1/2" roofing nails. Tape your joints with thinset and fiberglass tape. Trowel on thinset and set your tiles. You will never have any problems...
