shower pan
shower pan
I would like to know how to put in a shower pan on a cement floor that is out of level. Tthe pan is made out of acrylic and neo shaped. I'am having a bad time with it. thanks Joe 4h
Hi
You can mix a pail of mortar mix(sand and cement) and spread it under the shower base. Then set the base onto the mortar and push it down into it....check it with a level and then wait till it sets....you now have a level basin...and it;s solid.
