ceramic tile border on wall
Old 03-13-02, 09:12 AM
zalyx1
Just laid ceramic tile on floor of bath and ready to put up 2 1/2 inch tile border on wall around perimeter. Is it best to stagger grout lines or match them up to floor. Or is it a matter of preference ?
Thanks in advance for any info.
Old 03-13-02, 03:34 PM
A
Hi
I like to line them up...but that's just me....lay some out dry and stand back and look at them a while...then you'll get a better idea if you like it or not.
Old 03-13-02, 06:35 PM
zalyx1
Exactly what I did. Hard to see in a 5x7 bath though ! Figured if I have a hard time seeing so will everyone else (except the mother-in-law) so it doesn't really matter which way !
Old 03-13-02, 07:15 PM
T
Received 1 Upvote on 1 Post
Aligning grout lines
Most forum posters report that staggering grout lines between walls and floors tends to hide many sins. It is of course a matter of personal preference.
Old 03-15-02, 06:50 PM
zalyx1
Finished grout today-looks good thanx to this site ! One question though: If you use a sealer on the whole floor , does that replace sealing grout lines as well. Is it preferred to seal whole floor as opposed to just grout lines ? Do you wait same amount of time to seal whole floor as you do before sealing grout lines?
O.k. three questions.
Thanx again, Bill
Old 03-17-02, 03:27 PM
T
Sealing grout
Glazed ceramic tile does not need sealing. The glaze, which is kiln fired at a very hight temperature, seals the tile. The grout is however porous and tends to absorb oils, soils, and stains.
