Grouting problems
Grouting problems
Vicki
Hi Vicki,
Your problem is not unusual. I would mix the remainder of the grout and finish the job. I wouldn't change anything at this time.
When all of the grout has dried a couple days, you can use an acid cleaner available at Home Depot or Lowes to clean the surface of the joints. I think you'll find that the discoloration does not go into the joints. It's only on the surface.
Here's the one Home Depot sells...
TILELAB®
SULFAMIC ACID
CLEANER
• Removes grout haze, mortar residue and efflorescence
• Etches concrete
PRODUCT DESCRIPTION
Concentrated crystals that mix with water to make a mild, safe to use, acid cleaner. Removes dried Portland cement grout haze and mortar residue from tile, concrete and masonry. Safe for use on colored grouts. Removes hard water deposits, efflorescence and also etches concrete.
USES
Use on all colors of grout, tile, clay pavers, concrete, masonry. Do not use on marble or other polished stone. May etch some glazed tile.
MIXING
Mix solution in a plastic container using clean, warm water. Don't mix in metal container. Wear rubber gloves and eye protection. For removal of light mineral deposits and Portland cement grout haze or mortar residue on unglazed quarry or glazed tile with colored grout, mix 2 to 3 oz. (57 to 85 gm)
with 1 gallon (3.78 L) of water. Mix 6 to 12 oz. (170 to 340 gm) to 1 gallon (3.78 L) of water for unglazed tile or masonry that has gray-colored grout joints. For etching concrete or heavy-duty cleaning of old concrete, mix a minimum of 12 oz. (340 gm) to 1 gallon (3.78 L) of water.
Note: Do not use on marble or other polished stone. This product may etch some glazed tile. Test solution on a small, inconspicuous area before proceeding. Don't allow product to contact metal fixtures
DIRECTIONS
Concrete and grout should be cured a minimum of 10 days and be clean. Saturate unglazed tile, concrete, masonry or grout with clean water for one hour prior to application. Apply solution to wet surface and scrub with a nylon bristle brush. Work in small areas. Flush with water immediately
after brushing. Do not use repeatedly or surface damage could occur. For heavy concrete etching, allow solution to sit for up to 30 minutes prior to flushing with clean water.
COVERAGE
1 gallon (3.78 L) of sulfamic acid solution will clean an approximately 300 sq. ft. (27.87 sq. m) area.
PACKAGING
1 lb. (.45 kg) container.
ITEM CODES
TLSAC1
CAUTION
Keep out of reach of children. Do not take internally. Contains sulfamic acid. Use only with adequate ventilation. If swallowed, immediately drink 1 or 2 glasses of water and call a physician or poison control center. Avoid breathing of dust or contact with skin or eyes. Wear rubber gloves and eye protection. Use respirator if necessary. In case of eye contact, immediately flush with water and call a physician. For skin contact, wash thoroughly. Do not transfer contents to unlabeled containers. Close container after each use.
Seal Beach, CA (562) 598-8808 Technical Support (800) 272-8786 www.custombuildingproducts.com Manufacturing facilities nationwide
TILELAB®
SULFAMIC ACID
CLEANER
• Etches concrete
PRODUCT DESCRIPTION
USES
MIXING
DIRECTIONS
COVERAGE
PACKAGING
ITEM CODES
TLSAC1
CAUTION
