Granite tile counter tops
I recently did the above, I cut 1" 3/4 by 12" strips for the front edge, A professional in passing mentioned a makimbo kit that you put on your angle grinder that gives a nice rounded edge Has anyone heard of this ? Where do I get one!
Hi
Yes there are cutting wheels that fit your angle grinder the will cut a round profile...but they're only as accurate at you are ...and they are not cheap. You might be better off to go to a tile and marble shop, that is set up to do this type of work, and have them do it for you.
