Repairing cracked marble
We are putting in marble floor in master bathroom. Some marble is cracking before installation.....is there glue (epoxy?) to repair it? Also we assume it will also crack a little during normal wear and tear. what product should we use for these cracks.. Thanking you inadvance
Hi DocK
You can find an epoxy called "Akemi" at marble fabrication shops. Also check out www.akemina.com/about.html
It might be easier to use your broken tiles for cuts you're going to make.
