sealing grout
Old 07-01-02, 04:22 PM
pam carrillo
sealing grout
I tiled my shower using "premixed ceramic tile adhesive & Grout-Sanded". I got silicone grout sealer. It says not to use on apoxy grout joints. Is that what I have, or can I use this sealer
Old 07-02-02, 05:21 AM
diemeto
epoxy is normally used by pros, I doubt it is what you have but you should read the label on the grout that you used. BTW in the future do not use the pre-mixed stuff - it is more expensive and poorer quality then the mix it your self stuff.
