Wonder Board and Plaster Walls
I'm redoing the shower in a house that is at least 40 years old. The shower currently has a tub with tile on the walls. I was planning on ripping out the tub to put in a show pan and replacing the walls with wonderboard and tile. The current walls above the current tile is plaster. Does anyone know the difference of the thickness between the plaster wall and the wonderboard? One last thing. The current tub is Cast Iron. I was told that this could easly be busted up with a five pound sledge. Is this true?
Thanks for all the help.
If the plaster is thicker than you can build up the tile surface with a little thinset - for bigger diff you can put a nailing strip on the studs to hold the wonderboard out further. If the plaster is thinner you could notch the studs behind the wonderboard a little - not a lot
The best advice is to shim out the wonderboard.You can use cardboard lath,and this is avaviable at most home improvement stores.You want the surfaces to be as close as possible.You can measure the thickness of the existing plaster......which is 1/2 inch to 3/4.........make sure then that the wonderboard is secures to the 2x4 studs.
