What next
What next
I recently resheetrocked my kitchen span. I have rolled on some PVA sealing primer 72 hours ago. I will be wallpapering this span. Should I apply sizing over the PVA? Apply paint first? Another type of primer? Please enlighten. Thanks.
I wouldn't use PVA as a wallcovering primer. Use a primer specially formulated for wallpaper such as Benjamin Moore's Wallgrip 3 or something similar. PVA primer can and will re-wet under vinyl which will cause either failure of the primer as in paper popping off or allowing the adhesive to soak in the wallboard making removal at a later date next to impossible.
prowallguy
prowallguy
