Primer for (new) lathe and plaster?
I have an old farm house. The origional walls are lathe and plaster. I just put a fresh coat of joint compound over all of the walls to even them out.
I thought I was going to paint , so I used BINS 3&1 primer on the walls to seal them. Now the wife wants to hang wallpaper. I read someplace that new plaster being papered should have been sealed with an oil based primer.
I've never hung wallpaper so I really don't know what to do. What is wall sizing and where do I get that??? How do I know how much I need? Is there something I can use instead of sizing?
My primary concern is the prime coat, no pun intended.
If it WAS supposed to be oil based is it too late to do anything about it??? Can I get away with just the BINS?
I assume you mean bullseye 1-2-3 primer. Zinnser's BIN is a pigmented shellac primer.
The bullseye is ok for a primer under wallpaper but oil base is superior for sealing the wall. It can be applied over latex paint.
Hi Mark
I used the shellac base. Because these were really old walls there was some bleed thru on the new plaster. I knew the shellac would seal that from doing woodworking.
Should I put an oil over that?, or can I get away with just sizing the wall and hanging the paper?
My dad always used shellac as a primer/sealer. I guess this was in the days before B-I-N and other Zinnser products. I went to the local Porter Paint store in KY, and they had no shellac. The guy did not know if they made it any more. I bought the Zinnser High Hide Odorless to seal OSB from bleed through. I have always found the Zinnser products to be very effective. You can check out their products and find one to meet your need at http://www.zinsser.com/subcat.asp?CategoryID=1
If wallpapering, sizing the walls is important. This will allow for easier removal in the future.
Zinnser's BIN is a pigmented shellac primer. Pigmented shellac is getting harder to find. Last time I went to the paint store after some, they were out of both BIN and their shellac.
Fortunetly oil primers have come a long way [latex too] I'll never forget when Kilz first came out Even with a respirator there is a big difference between sparying 5 or more gallons of shellac versus 5 gal of Kilz. But there are still times where shellac is the only primer that will seal a stubborn stain.
Yesterday while at the big box store I ran across a high hiding oil primer. It's made for covering grafetti. I bought a can, just in case the ole lady springs any more surprises on me.
