painting over wallpaper that has the vinyl coating removed
Received 0 Votes
I have a situation where the vinyl coating of wallpaper in a small bathroom had been removed which left the paper backing. Then, a primer was used to cover the entire area. Can I paper over this primer successfully, or even texture and paint? Help, please!
Received 0 Votes
i would prime that bathroom with a quality prime SEALER. Such as shields or kills or better yet bins. Open the windows and use a respirator if you are prone to fumes. Always best to remove the wallcoverings if you can....That backing can be substituted as a liner paper if its still tight on the wall..A fabric or cloth backed vinal might be good choices.
what you should have done is soaked that backing with a hot water/fabric softener solution & removed it. but.........at this point:
if you want to re-wallpaper, you should use a "wallpaper primer" now, then hang your paper. that will provide you with a nice slip (meaning a surface that lets you slide the paper around on the wal easily) & will enable you to remove it easily in the future.
if you want to texture it, you can now, but you'll have to prime again before painting.
Received 0 Votes
If the primer was a solvent-based primer, then go ahead and paint. If it was a latex (acrylic) primer, then you need to prime again with a solvent-based primer.
A latex primer may allow just enough moisture thru to cause the paste on the backing to soften and come loose. Then you have a real mess on your hands.
