Primer for (new) lathe and plaster?
I have an old farm house. The origional walls are lathe and plaster. I just put a fresh coat of joint compound over all of the walls to even them out.
I thought I was going to paint , so I used BINS 3&1 primer on the walls to seal them. Now the wife wants to hang wallpaper.
I read someplace that new plaster being papered should have been sealed with an oil based primer.
I've never hung wallpaper so I really don't know what to do.
What is wall sizing and where do I get that??? How do I know how much I need? Is there something I can use instead of sizing?
I assume you mean bullseye 1-2-3 primer. Zinnser's BIN is a pigmented shellac primer.
The bullseye is ok for a primer under wallpaper but oil base is superior for sealing the wall. It can be applied over latex paint.
Hi Mark
I used the shellac base. Because these were really old walls there was some bleed thru on the new plaster. I knew the shellac would seal that from doing woodworking.
Should I put an oil over that?, or can I get away with just sizing the wall and hanging the paper?
My dad always used shellac as a primer/sealer. I guess this was in the days before B-I-N and other Zinnser products. I went to the local Porter Paint store in KY, and they had no shellac. The guy did not know if they made it any more. I bought the Zinnser High Hide Odorless to seal OSB from bleed through. I have always found the Zinnser products to be very effective. You can check out their products and find one to meet your need at http://www.zinsser.com/subcat.asp?CategoryID=1
If wallpapering, sizing the walls is important. This will allow for easier removal in the future.
Zinnser's BIN is a pigmented shellac primer. Pigmented shellac is getting harder to find. Last time I went to the paint store after some, they were out of both BIN and their shellac.
Fortunetly oil primers have come a long way [latex too] I'll never forget when Kilz first came out
Even with a respirator there is a big difference between sparying 5 or more gallons of shellac versus 5 gal of Kilz. But there are still times where shellac is the only primer that will seal a stubborn stain.
Yesterday while at the big box store I ran across a high hiding oil primer. It's made for covering grafetti. I bought a can, just in case the ole lady springs any more surprises on me.
