grasscloth wallpaper removal
Welcome to the forums!
Grass cloth is usually the easiest wallpaper to remove
Peel the top layer off of the wall, then wet the backing and gently scrape it off. With a little care, grass cloth can be removed with no damage to the wall
Grass cloth is indeed easy. But this you need to spray down with hot water or DIF stripping fluid with a garden sprayer. The whole thing should come right down. Give it time to work, at least 30 to 45 minutes.
