What to use to clean drywall after wallpaper removal
What's the best method and/or cleaning solution for cleaning the drywall before Guardz?
Will 50/50 water and vinegar solution work?
Received 0 Votes
It is difficult to answer a question when the details are not clear. Guardz is a Zinnser acrylic sealer. If applying to already painted walls, walls should be washed down with TSP (trisodium phospate) to eliminate soil, repairs made and sanded smooth when dry, and either affected areas or all walls sealed. Read and follow label directions. For more info about Guardz: http://www.zinnser.com/product_detail.asp?ProductID=27 For application tips, click on Brochure.
Received 0 Votes
I agree, I rarely use TSP on the interior, other solvents and cleaners are easier to work with inside. TSP is great on the exterior where you can rinse it with a water hose or pressure washer
