Wall Paper Removal - Un-Primed Walls
Help!!! I am attempting to remove paper from walls that were apparently not primed. The top layer came off ok, but the bottom paper won't. Besides being a mess it is beginning to mess up the sheetrock. I'm using DIF, but it's not working very well. Help!!!!
When you get to the point that paper will not come off you have one of two options.You can proceed with removal and deal with whatever patching and priming are needed to restore the surface or stop stripping and prime with 100% acrylic primer or oil base such as Kilz.Light patching may be needed after primer coat.
