we are living in a fairly new manufactured home that has decorative wall board( not sure of correct name)instead of drywall anyway i would like to add a wallpaper border in my livingroom ,but am not really sure how to get it to stick without ruining the wall board. it's a shiny smooth surface with vertical strips every so often to cover the seams. any suggestions?Read More
Hi,
We read through your instruction to hang wallpaper, and wanted to clarify how the inside and outside corners are to be cut. When you overlap the two strips at the corner and make the cut from top to bottom, are both
strips to be cut through, peeled back, the cut off pieces from both strips removed, and then the two strips seamed back together at the cut line with no overlap? Also, if you end the wall paper at an outside corner (ie
no wallpaper on the adjoining wall), how far from the edge of the corner to you suggest the wallpaper to stop, and is there any special edging, like the clear plastic corners, that you recommend.
Thanks
Mike
Read More
