resurfacing textured walls to wallpaper
Old 10-11-00, 10:03 PM
Guest
Post
Is the process for resurfacing textured walls (into flat) a complicated process? Is this best recommended for an expert or something that can be done by ourselves?
Old 10-18-00, 03:41 AM
mikejmerritt
Post
Welsh_99, Skimming walls is not complicated but does require a technique that you can't quickly learn from a forum, books or video. Most times a DIY'er will be finished with a project before they catch on and will wish they had never started. If you go for it remember that light coats feathered out is better than a heavy coat or two that will need sanding for hours...Best of luck..Mike
