removing wall paper paste
Old 12-29-09, 12:41 PM
D
How do you remove wallpaper paste once you have already gone over it with a primer?
Old 12-29-09, 01:06 PM
Received 257 Votes on 227 Posts
Welcome to the forums!
The paste should be removed before the primer is applied.
At this point, there isn't much you can do other sand [maybe scrape a little] and reprime. Most any solvent based primer will seal wallpaper adhesive. Zinnser's Gardz is the only latex primer that will do a good job of sealing the adhesive.
