wallpaper
I have just purchased some industrial wallpaper. I want
to hang it on latex walls. Is there anything special
I have to do?
I have to do?
You'll need to lightly sand the surface to get good adhesion first.
Rub with sandpaper or use an electric sander. Then wipe down the walls and leave to dry.
If the paper you are using is heavy then you need to make the wallpaper paste a little bit thicker by adding less water when you mix.
See http://www.housedoctorintheuk.co.uk for more hints and tips and the new HouseDoctor clinic!
