ref. can I hang wallpaper on a textured wall
Old 01-24-01, 08:03 PM
Guest
Question
Do I need to sand or put anything on a textured wall before I hang wallpaper or can I just put wallpaper up over the textured wall.
Old 01-25-01, 01:54 AM
Guest
Question Hanging wallpaper on textured walls
I would also like to know if something needs to be done to the textured wall before wallpapering. I hope that someone will give some feedback. Thanks
Old 01-25-01, 06:42 AM
mikejmerritt
Paper can be put on a textured wall the same as any wall as long as it has no sheen. Paper will draw into the texture as it dries and cannot be expected to hide it. To cure the texture problem you would need to float or use liner. The textured papers also work very well in this situation. If details on any of this are needed get back..Mike
