Peel & Stick Wallpaper
About a year ago, I covered the lower half of my bathroom wall with peel and stick wallpaper. It is now peeling off the wall at the top and bottom edges. I asked the store what I could use to fix it. They told me there was nothing I could do. I do not want to tear it off and start over. Is there anything I can use to make it stick?
Received 0 Votes
humidity is the problem...
The paste on peel-and-stick and pre-pasted papers won't hold up in a humid environment like a bathroom or kitchen.
You need additional paste for that. You can treat the parts that have peeled, but eventually the middle will pull away. It won't peel, but you'll be able to tell its loose.
The only real solution is to pull it all off and redo it.
