Wallpaper Substrate Options?
Old 05-30-19, 04:56 AM
I have a 3 season cottage and so drywall is not a good substrate. I understand that plywood that has been properly primed and lined is an good option. Are there other substrates such as white "hardboard" - "masonite" that would also work and if so, would the prep be similar to plywood?
Thanks.
Old 05-30-19, 05:22 AM
Marq1's Avatar
Received 1,142 Upvotes on 1,035 Posts
If you like the look, OSB could be used, it's a little bit waterproof and cheaper than plywood.
For interior you could get away with very thin material!
JayStephen voted this post useful.
Old 05-30-19, 05:24 AM
Received 759 Upvotes on 664 Posts
Welcome to the forums Jay!
Why do you think drywall isn't suitable? As long as it's painted and kept dry it should hold up fine during both hot and cold exposure.
Old 05-30-19, 06:08 AM
Thanks.I like drywall but this is a 55 year old cottage I am renovating and with drywall I have the added task of taping and finishing (dust) in a space in an existing occupied area. A "panel" of some kind would be easier even if a little more expensive. I might even use 1/4" GS1 plywood.
Old 05-30-19, 08:50 AM
Thanks. I think OSB has a little too "rough" a finish.
