Paste to Wall Prep
Paste to Wall Prep
Hi, have wallpapered many times using conventional wallpaper that you paste and hang, Have now been tasked with hanging new style paste the wall wallpaper. Not a problem in the application, just the preparation. The existing old 'paper comes off a treat but there is lining paper underneath with a lint like/peach fuzz texture now the original wallpaper has been removed. Please advise the best way to prepare, should I wipe with water and vinegar to remove the 'lint' - should I then seal with water/PVA (would love recommendations of ratios if so)?
I would like to keep the existing lining paper (even though it was hung vertically) to save time.
(First post- be gentle with me please).
Thanks in advance
Thanks in advance
Thank you Marker, that answers the question regarding the liner paper.
Do you have any suggestions regarding the necessity of a PVA / water seal, and if so what ratio?
Many thanks in anticipation - LondonPlane
Hi Marker, it's just that I don't want the paste to wall paste to be absorbed into the liner and the paper not adhere properly...
Appreciate your help Marker, hopefully someone else can advise re seal priming?
All the best - LondonPlane
