How to hang wallpaper border without wetting it
Old 01-05-02, 08:11 AM
Guest
We are renting and the landlord will not let us put up a border that is permanent. Is there a way to put it up not using tacks or staples?
Thanks!
Danna
Old 01-07-02, 02:46 AM
B
stencil instead....
A properly prepped wall will not be a problem when the border needs to be removed. Prime the area with Shieldz, then hang the border. Use a past activator instead of water. When you need to remove it, just wet with water and it will come off. Convining the landlord is tough.
Instead, use stencils to paint a border. The landlord will probably paint the walls anyway after you move out.
