Spackle put on wallpaper
Is there anyway to remove spackle from wallpaper that was put on by an idiot tenant in my rental property other than scraping (Solvents)?
Received 0 Votes
Just wet the death out of it and use a rag to rub it away. I am fairly certain that your wallpaper has a vinyl coating so the water should effect the paper, just make sure you aren't too vigorous with the rag on the actual wallpaper surface.
