removing a wall
I am trying to install a bathtub surround in my bathroom. (That part, I can do) I took the tile off the wall last night as I feared the tile was leaky. I was correct, my wall is black and wet.
My questions are:
1) How do I remove large sections of drywall?
2) Should I have any fear of what is behind that moldy drywall?
Thanks in advance
My questions are:
Thanks in advance
You need to be on the lookout for electrical and or plumbing lines that may be behind the drywall. As for removing it, you can cut 1/2" drywall with a sharp utility knife. To do this, I have cut the edges and then broken out the drywall in the center.
Good Luck.
Good Luck.
