Fitting a round peg in a square hole
Old 10-01-02, 04:07 PM
eyeguy99
My kitchen ceiling has two square holes. The previous owner put two round fixtures up. I like the fixtures, but the corners of the square ceiling holes peek out. Is it possible to tape and mud these corners? Any other suggestions? Thank you!
Old 10-01-02, 05:35 PM
TomBT
Yes, and if the areas are fairly small you may get away without using the tape - just go with the spackle. I would say that if the hole size is larger than a nickel, you might have to tape. Otherwise just apply the spackle and see what happens. Carefully sand the areas after they dry.
