Would someone please explain how to use a T-brace for ceiling....
Please pardon my ignorance on this one. It seems to be a very simple device. But my simple mind can't figure out the details. So, the long 2x4 should be how much longer than the ceiling height? 2 inches? And what is the cross part made from? Width?
Also, how do I use it to prop up the drywall to the ceiling? Do I need to hold one end while the t-brace holds up the other? Can the t-brace hold up the entire 4x8 sheet?
Please help.....
Thanks, Rob
Please help.....
Thanks, Rob
helped my dad build my 1st house 25 years ago. he made one and we used it for the entire sheetrock job. i know what it looked like and how we used it. can tell you now though that ever since that job i have gladly paid $20 a day to rent a sheetrock jack.
Using T Braces
I'm no pro, but I just finished hanging sheetrock in a 1000 square foot basement by myself. I didn't rent a drywall lift (I hear it's great) because I can only work 1-2 hours each day. Instead I used my old 3x5 work table to make my own lift. I attached 2x4 u braces extending over the ends of the table and built 2 t braces about 2 feet shorter than the ceiling height. Then I slid the t braces into the u braces so that the ts could slide up and down vertically. Get the picture?? With the base of the ts on the floor, I was able(by myself) to lift a 4 x 8 sheet up to rest on top of the ts. Then I slid one T up and clamped it with a C clamp. By repeating this sliding and clamping of each T brace the sheetrock can be lifted up and into perfect position. It worked great for me!! Now I'm spackling and sanding. Oh joy. Good luck to you.
