removing textured paint
How do I remove textured paint from my drywall. I've tried sanding and scraping. Please help!
Received 1 Upvote
1 Post
If you mean popcorn texture from a ceiling, it is relatively easy, but very messy.
Hang plastic down the walls over a good dropcloth on the floor.
Spray the popcorn texture with water from a Windex-type spray bottle, and scrape it off with a 10"-12" sheetrock blade.
Wet it only enough to be able to scrape it easily. Be especially careful over seams.
Experiment in an area where there is no seam.
Once you've scraped it all off, repair the drywall and seams, lightly sand, prime and paint.
Good luck!
Mike
Good luck!
Mike
Spal: Thanks for the question. I never tried the method suggested by OldGuy, but what I recently did was screw home 3/8" blueboard over the wall with the f-ing textured paint (sorry I was angry at the last tenants), and taped/mudded. Put on 2 coats of sheetrock primer and it looks awesome. Might be more work, but no waviness and looks very clean. I like be able to collect ideas from this board and decide which works best for your situation or create a backup plan. Good luck. Peace: e3 - spamman
Icicle type ceilings
My ceilings have the texture that looks like little icicles. It is not the popcorn type. The texture actually hangs down and is pointy and sharp. It also has at least one coat of paint over it. I still want to have some texture to it when finished. How can I remove or minimize the texture? I was thinking of using some type of roller to just break off the bulk of the texture and just leave what remains. Should I think about sanding?
