repairing plaster wall
I'm getting ready for a move and I've got a problem. I have a room w/ plaster over lathe walls. On one wall, the plaster has broken away from the lathe in a couple of very large spots. I would hate to rip out the whole wall. Is there a way I can smooth the wall. I've thought about cutting out the bad spots and fitting drywall in the hole but there has to be a better(and cheap) way. Any suggestions would be helpful.
If the plaster is otherwise solid, there are plaster washers (www.vandykes.com) that can pull the loose plaster back onto the lathe and studs. Then localized patching and a skim coat is all you need. Of course the benefit to opening up large areas of wall is you can update electrical and plumbing easier.
