drywall ceiling
Old 12-09-02, 11:57 AM
i_hammer
drywall ceiling
Is it ok to attach drywall directly to the ceiling joists? I have seen insturctions on how to attach to furring strips along the joist, but would rather not give up any more head room than necessary.
Also, are you supposed to put a vapor shield / plastic sheathing along the ceiling as is done on the wall?
Old 12-09-02, 06:08 PM
Yes.
Yes. Unless, the ceiling is the insulated floor of a room above. You don't want to have two vapor barriers on the same floor or wall.
Old 12-10-02, 06:07 AM
i_hammer
Thanks for your comments!
Just got paranoid as I had already begun placying the drywall on the ceiling directly to the joists.
I do wish, however, I had used the furring strips. I planned ahead enough to run wiring for the planned light fixtures, but if those plans change any time in the future, it would be much easier to run wiring through the open spaces between the ceiling and the joists that the furring strips would provide.
Live and learn!
