How to replace a textured ceiling
Old 12-10-02, 02:26 PM
JOEYRM7
I am attempting to replace a textured ceiling. What is the easiest way to do this. Obviously I can rip down the existing sheetrock and replace. Sanding is way too messy. I tried dry scraping but I can't seem to get a level surface. The texture was put on using spackling compound with a textured roller (fairly heavy) which has been painted over twice. Any suggestions would be appreciated.
Old 12-13-02, 05:39 PM
T
Received 1 Upvote on 1 Post
Remove textured ceiling
If you want a smooth ceiling, you are in for a lot of work with scraping and sanding.
Old 12-13-02, 08:12 PM
JOEYRM7
Thanks for the response. Unless I hear otherwise it looks like the old ceiling is coming down and a new one put up in it's place. It has to be easier than sanding.
Old 12-14-02, 05:33 AM
Mike Swearingen's Avatar
Cool
Have you tried to skim-coat a smooth surface over the texture?
Depending on how rough the texture is, you should be able to do it, and it would be much easier and less expensive.
I would at least try it in a small area to see how it looks.
Good Luck!
Mike
Old 12-14-02, 09:47 AM
michaelshortt's Avatar
I think if that dosen't work I would install new sheetrock over the old. If you have blown in insulation it is a real mess. Of course the old sheetrock should be somewhat flat.
Old 12-14-02, 02:11 PM
JOEYRM7
I had to bite the bullet and removed the existing sheetrock and replace with new. The texture was too thick to effectivly level. Thanks for the help guys
