Dry wall
Is there a way to mark the hole for an outlet or switch box, in new drywall, other than measuring the distances from the edges?
Thats the only way if you cut the hole prior to hanging your rock. Your other, and better, option is to measure from an edge of the rock to the edge of your box, hang your sheet, then cut out the box with a roto zip(or similar) tool.
[QUOTE]Originally posted by coops28
Thats the only way if you cut the hole prior to hanging your rock. Your other, and better, option is to measure from an edge of the rock to the edge of your box, hang your sheet, then cut out the box with a roto zip(or similar) tool. :
I have a Rotozip. Do I let the Rotozip run around the outside of the box to get that "Perfect Fit?" Sounds much easier than the guess work of measuring.
You could put marker on the box lip and hold the drywall in place to transfer the mark.
That sounds like a good idea. What would I use to make to mark?
Maybe some chalk?
Maybe some chalk?
There used to be marking systems that you could fibe. My suggestion would be to use a stamp pad. Ink the box with the stamp pad, move the drywall in place and then lightly tap the drywall to transfer the mark.
I have read about using lipstick, but I go without and my wife would kill me if I used hers.
Thanks for the tips. Like you, think I'll pass on the lipstick. The inkpad sounds like a good trick and a stamp pad sems like it would be about the right size.
Previous Thread
Next Thread
