sheetrock by myself?
spamman's Avatar
02-08-03, 06:48 AM   #1
Can someone tell me a way to hang 4x8' sheets of 3/8" drywall onto a ceiling by MYSELF? I am having a hard time finding someone to help me this week and I need to get it done. I will be hanging about 5 sheets to cover old plaster and crappy texture.
Any fixturing or tool to lift one side while I lift the other and screw it home? Peace: e3
IWD1's Avatar
02-08-03, 07:50 AM   #2
IWD1
Either rent a drywall jack from your local tool rental and supply or you can make 2 T bars out of 2x4 studs that are little lower than the ceiling when they are stood on end and you can use the T bar supports to hold the drywall.
scooterJ's Avatar
02-10-03, 07:22 AM   #3
scooterJ
I have done it both ways...Rent a unit or build a wood T.
The rental method is way faster, plus you can raise the drywall and mark cutouts, lower it again, make the cuts and raise it again...in seconds.
dickh's Avatar
02-10-03, 08:46 AM   #4
dickh
i read an article in the family handyman that said you could use 1/2" sheetrock on a ceiling IF the ceiling joists were 16" oc or less, and no texture added. personally i prefer 5/8 on ceilings. if you use 3/8 i will bet that within 6 months your ceiling will be sagging.
spamman's Avatar
02-10-03, 01:52 PM   #5
dickh: I appreciate the help. I am putting the 3/8" over 3/8" plaster that is on 3/8" blueboard. The plaster is solid as hell and only has the annoying texture. No sag in the plaster and no leaks (new roof). I cannot see a need for 5/8" for this application. therefore the use of the 3/8" light stuff. If it were directly to the beams and holding up insulation, then 5/8" is the way I would go. Peace: e3 - spamman
