miniature recessed lighting fixtures
I have an application that I need to use something of a recessed lighting fixture with an eyeball that measures in the area of 2 to 2.5 diameter. Definitely low voltage.
The basic application is simply a 6 pine ledge that boarders the walls in a 400sq/ft room for a chair rail/counter top for drinks etc. This 6 ledge will have a boxed in effect with another piece of 6 pine mounted below it on an angle to mount some form of lighting fixture pointed to the floor spot, flood, narrow beam the bulb doesnt make a difference. The lights are to be spaced out at a 2 1/2 to 3 interval depending on the solution that I go with.
Ive looked and called everywhere for possible application solutions. The best solution was a miniature recessed housing that measured 2 1/8 using 2 ½ trim with a 1 eyeball to angle the light back towards the wall/floor.
Kgarthr, Hello & welcome to the forum.
Did a quick google search and came up with this link, looks like it could possibly work for your situation.
http://www.lightinguniverse.com/prod...px?family=5513
Hope this helps.
Hope this helps.
Thank you for the URL, however I'm looking for an eyeball type fixture since I am installing them on an angle - unless you know of another way to mount them?
Well it seemed like a good idea
They've got alot of lighting ideas at that site, found 'em on google. I think the search string I used was interior accent light fixtures. Good luck,
Previous Thread
Next Thread
